liferider
Looking forward to retirement
Ok I use 2 different enclosed trailers. Depending how many bikes I take or what I'm doing. I have a 20' x 7.5 wide set up with a full tool set any mechanic would love. This trailer is set up with 4 removable Bike Pro roll in chocks. The second trailer is a 10' x 8' with 2 Bike pro rollin chocks. Depending on what front tire you have depends on if you use the screw in inserts. Inserts are used on skinny 21'' tires. Bikes with wide tires like the Ultra Classic do not use the inserts. Also depending on the back of the rear fender and where you want the back wheel support to grab the back of the tire depends on what set of bolt holes you put the back wheel support in. Either top, middle, or lower holes. The Bike pro chocks can be ridden into, then step off your bike and have it hold it's self up while you attach your soft straps around your tripple tree, and wratchet the bike down. I use sub floor D rings, and rail systems to tie the bike down.
