PHATASS
Bike gradually started to crank over really slow over the past few weeks and my HD battery eventually died after being installed just under a year. Noticed that when I turned on the ignition switch and headlight came on, the battery volts dropped from 12.90 down to 12.20.
Installed a new Yuasa 315 CCA properly charged battery and thought it would solve the issue. It did...sorta. Now when I turn the ignition switch on, the volts slowly drop from 12.90 down to 12.60 and bike will slowly struggle to turn over. Checked the starter and it's putting out 12.50. Definatley not a quick crisp start up like it should be. Checked if the scoot was charging the battery and all is well. It's almost as if the headlight is drawing to many volts from the battery on start up. I did install the HID kit a few months back and hoping it's not related.
