ezrstl
I was reading through some of the 'Fuel Injection' threads and thought I might try to clear a few misconceptions of Big Dog's S&S Fuel Injection.
The S&S VFI that Big Dog uses on all of the fuel injected models is a 'self tuning' system that utilizes Wide-Band O2 sensors. The Wide-Band sensors have the ability to 'tell' the ECU to send as much fuel to the engine as it needs. The 'bottle-neck' on the entire system is the programming restrictions from the EPA. Hopefully my explanation on this will be clear...
Every EFI Big Dog has a Base Fuel Map. This ONE map controls most of the fuel to both front and rear cylinders. The Base Fuel Map cannot be changed in any way; the owner and dealer are both 'locked out' from making changes to the Base Fuel Map. Why? In order remain EPA compliant. Now, it sounds like I just contradicted myself, because I began by saying that the Big Dog EFI is a 'self tuning' system. So, if that Base Fuel Map cannot be changed, how then does the EFI system make fuel corrections? Remember, I said that the Base Fuel Map controls most of the fuel. The fine tuning adjustments are made by what is called the 'Adaptive Maps', and each cylinder has it's own Adaptive Map.
Let's say you are cruising down the highway in 6th gear at 2700 rpm, and at 23% throttle. Your Base Fuel Map in the ECU tells the injectors to run at pulse width of 3.27 ms (the bigger the number, the larger the pulse width, the more fuel the injectors blow at the engine). But because of the non-stock exhaust and air cleaner you are running, the pulse width of 3.27 ms isn't enought fuel to keep the engine happy, and if we cannot change the factory set Big Dog Base Fuel Map; because the EPA's restrictions locked us out, what is going to take care of the lean condition?
This is where the Adaptive Maps come in; and each cylinder, front and rear, has it's Adaptive Map. The Adaptive Map get's fed information from the facotry Wide-Band O2 sensor in each exhaust pipe. The O2 sensor tells the Adaptive Maps to either richen or lean out the Base Fuel Map. Basically, if the Base Fuel Map is not rich enough, the Adaptive Map tells the ECU to add fuel or richen the mixture by increasing the pulse width of the injector. So, when we are cruising down the highway in 6th gear at 2700 rpm, and at 23% throttle and the 3.27 ms pulse width isn't enought fuel, the Adaptive Map will add to the pulse width in order to keep the engine happy. The Adaptive's will also lean the pulse width if needed.
Now, enter the friendly EPA for a second time around. These Adaptive Maps have a limit on them too. The EPA's restrictions are that the Adaptive Maps can only move around 28% from the Base Fuel Map. That sounds like a lot and in some cases it is. But, add more compression and a more aggressive cam to the non-stock exhaust and air cleaner you already have, and the Adaptive Maps will 'Limit Out' and your Check Engine Light will come on. The light is telling you that the engine wants more fuel in a certain area (throttle position/rpm).
Once we make these type of modifications, we need a fully programmable ECU. The S&S unit allows us to make full and complete fuel corrections to the Base Fuel Map and has more un-restrained Adaptive Maps that are able to run and make the fine tuning changes the engine wants.
I haven't run into an EFI Big Dog that had air cleaner and exhaust mods only and needed the programmable S&S ECU. So far, all the bikes with just air cleaner and exhaust mods, the factory Big Dog ECU could handle the fuel needs. This is not to say that there are not Big Dog's with just air cleaner and exhaust mods that might need the programmable ECU; we just haven't run into them yet.
I have tuned 117's, 124's and a 145 using the S&S ECU and have had excellent results everytime. It a great piece of hardware with excellent fuel and timing management software. The only thing that must be changed on an EFI Big Dog when using the S&S unit is the ECU itself. Unplug the factory unit, plug in the programmable S&S unit and put it on the dyno in order to build the Base Fuel and Timing Maps. Then ride it and let the factory Wide-Band Exhaust Sensors feed information to the Adaptive Maps and let them make the final changes and tune on the Base Fuel Map. Another feature of the S&S ECU is after you ride it for a month or so, you can merge the Adaptive Maps into the Base Fuel Map, but that's a whole 'nuther story...
I have also worked with HD's Race Tuner, the Power Commanders on HD's and Metrics, and the Bazzaz unit for sport bikes. They all are designed to allow the user to optimize injector pulse width, and build the timing maps. Some like the S&S unit, Power Commander V, and the ThunderMax also give exhaust gas analisis to give even greater power to properly tune the engine.
Finally, I hope that this doesn't sound like an ad for S&S. It isn't. I only hoped to clear a few misunderstandings about the EFI controller that Big Dog elected to use on their bikes.
