I have vance hines radious. It does smoke when you sit still and rev it up. When I bought the bike it did not have baffles in it. In the state of Maryland it will not pass inspection so I put baffles in and that's when a friend was behind me and noticed the smoke when I took off. I don't know how to determine what jets are in it. The bike has no loss of power and once you shift to a higher gear the smoke clears up even if I stay into it no smoke. The smoke when at idle starts black as you rev and turns blue as you let off.Gonna need more info that what you provided. Where is your accelerator pump set at (how many turns out?). What jets are you running? What pipes and air cleaner do you have.
Does it smoke at idle when you rev it up? If so maybe it's just your accelerator pump set to high.
As long as it's not blue smoke indicating an oil leakage issue then I would think it just a rich adjustment issue.
