BIG DOG MOTORCYCLES OEM 250 REAR AXLE CAPS
Hello i'm looking the rear axle caps for the model from 2006 mastiff with de 250 rear tire i search on ebay, HDM, BigDog site and i only find the axle caps for the 300 rear tire... If you know someone that have one that would be much appreciated.
mleach72
Yeah, I would call them and get them to clarify. They say they only fit the 300 tire, but it also says it fits 06-10 mastiffs. 06 had a 250 tire.
I can see how the title might be a little confusing, 250 was probably omitted from the title to not generate additional confusion about all the other 250 bikes it won't fit. 2006 Mastiff is the only one. It does state fits 2006 Mastiff in the description. Based on ya'll question, I went ahead and removed 300 from the title.
As the item description mentions, the difference between the 250 Mastiff and 300 Mastiff is just the diameter of the bolt holes. What bolts are on the 2006 Mastiff? Derek would know off the top of his head, I don't know what they used on the 06 Mastiff. 10-24 Button Head Cap Screws were used on the 300 bikes, that I do know. 06 Mastiff use 8-32 like the some earlier models?
I don't know if people don't see it but we tried to make it as easy as possible for folks. You can filter by year/model with a dropdown at the top of almost every page using the main drop down and just a general keyword search.
Here's the link to the axle caps for the 06 Mastiff.
S
So your saying that the axle caps for the 300 mastiff fits the 250 mastiff from 2006-up? I have interest on the BIG DOG "MOTORCYCLES K-9 REAR AXLE CAPS TIRE TEARDROP STYLE MASTIFF POLISHED" i don't like the spikes they seems outdated on the bike... best regards.
mleach72
@Pddain has an 06 mastiff. Maybe he can remove one of the screws and figure out what they are.
S
Yes they will fit, the question I only have is if the bolt size on yours is a hair smaller than the recessed area might not be identical but if you put new ones on both sides, difference would be rather mute.
Pddain
PHTM II
I didn’t catch this until now. Be happy to look at the screw size if you need me to. Iron Horse cycles in Decatur Al. made my covers. They measured it and cut them then polished them. I can ask Dan if they can make another set, but Eric and HDM would be a better source. Let me know what you want.
thank you my motorcycle will arrive 14 of november i will see if i can recover them first, if not i will go with the second plan.
