Big dog is back!
We’ve picked ourselves up and dusted ourselves off. Now Big Dog Motorcycles is back on the road and better than ever.
http://bigdogisback.com/
The Story
Big Dog Motorcycles is an American motorcycle manufacturing company specializing in high-performance, on-road cruisers. Founded in 1994, the company has grown to become the largest production-custom motorcycle manufacturer in the world, delivering over 30,000 motorcycles across the globe. The company’s production grew from building a single motorcycle its first year to peaking at production rates and exceeding 25 motorcycles per day in 2007. The company began slowing production at the onslaught of the “Great Recession” in early 2008 and eventually halted production for three model years (2012-2014) as the US recovered from the aftermath of the worst economic downturn since The Great Depression. New production motorcycles might have been out of the public’s view, but they were far from out-of-mind:
“We weathered the storm behind closed doors, refining our motorcycles and business strategy. We were testing new concepts and designs that would have been otherwise impossible if motorcycle production would have continued in the status quo. We had a chance to get back to our roots of hand-craftsmanship, high-performance, and production-grade reliability.” —Matt Moore
The 2016 model lineup is the pinnacle of 22 years of experience in the motorcycle manufacturing business. Among the many updates to the lineup, the most notable include updated and completely re-designed electronic systems, a bulletproof transmission, and employing the largest production motor ever to be placed within the confines of a Big Dog frame— the S&S 124.
If you seek premium performance and custom styling, combined with production-grade reliability and pricing, you will not find a finer motorcycle in its class. Welcome to the aftermath.
Who We Are
Big Dog Motorcycles is more than a brand; it is an army of enthusiasts with a passion for life and the vehicles we choose to navigate it. We are always in pursuit of our next adventure, and we don’t believe in sitting still and observing life from a nice, quiet little box. We experience the road with all five senses. We may not know what’s over the next hill, but we’re ready to find out, and we know it will be one hell of a ride. When we ride, we never stop moving. It’s in our blood. Our bikes are more than a comfortable cruise that delivers us to our next experience— the ride is the experience.
Big Dog is back and badder than ever. We’ve been in the garage, refining the best-selling chopper in the world, the K-9, and now we’re bringing it to you, crafted with aggressive precision for the most demanding riders.
Take your next journey on a bold, cutting-edge Big Dog motorcycle!
K9
This chopper-style cruiser has a strong silhouette, bold, cutting-edge style, and a killer sound.
US MSRP Starting at $ 32,995
Curb Weight
716 lbs Wet
Engine
S&S SuperSidewinder
Overhead Valve, 45°, V-twin
Fuel Capacity
4.4 Gallons Total
K9 Specs
Engine S&S SuperSidewinder, Overhead Valve, 45-Degree, V-Twin
Displacement 124 Cubic Inches (2,032 Cubic Centimeters)
Engine Finish Polished
Carburetor S&S Super G
Compression Ratio 9.0:1 with automatic compression release valves for Starting
Bore and Stroke 4-1/8 x 4-5/8 Inches
Pistons Forged
Camshaft 543
Ignition S&S Superstock
Transmission Jim's, 6-Speed, Right-Side-Drive, Close Ratio, Straight-Cut Gears,
1st Gear: 2.94 : 1
2nd Gear: 2.21 : 1
3rd Gear: 1.57 : 1
4th Gear: 1.23 : 1
5th Gear: 1.00 : 1
6th Gear: 0.86 : 1 (Overdrive)
Clutch Actuator Mechanical with internally-lubricated outboard output-shaft bearing support
Clutch High-Performance, Mechanical
Primary Drive Diamond endless-link Chain
Compensator Sprocket Yes
Final Drive 1-1/8 Belt, 130-Tooth
Speedometer Dakota Digital
Tachometer Big Dog Digital
Front Brake Caliper Performance Machine, 4-piston, Differential Bore
Rear Brake Caliper Performance Machine, 4-Piston, Standard Bore
Rotors Brembo, Full-floating
Wheels Forged Billet Aluminum
Rear Tire Avon 300/35VR18 (87V) COBRA AV72
Front Tire Avon MH90-21 56V COBRA AV71
F/R Tire Pressure F-40 PSI, R-42 PSI
Charging System 32 Amp
Battery Sealed AGM, High CCA output
Coil S&S, 3-Ohm, Single-Fire
Starter 1.8KW
Curb Weight (Wet) 716 Pounds
GVWR 1130 LBS
Fuel Capacity - Total 4.4 Gallons
Fuel Capacity - Main 4 Gallons
Fuel Capacity - Reserve 0.4 Gallons
Oil Capacity 3 Quarts 20W-50
Frame Rake 39 Degrees
Tree Rake 3 Degrees
Backbone Stretch (Over Stock) 4-Inches
Downtubes Stretch (Over Stock) 8 Inches
Frame Tubing Heavy-Duty, 1-1/2 inch O.D.
Fork Tube Length (Over Stock) 12 Inches
Front Suspension Telescopic, 41mm
Rear Suspension Fully-Adjustable Dual Gas Shock Absorbers
Seat Height 24.25 Inches
Ground Clearance 4 Inches
Wheel Base 82 Inches
Overall Length 108 Inches
Make it Personal
Want to make your motorcycle bolder, more dynamic and daring? Customize your ride by choosing from a variety of paint schemes, and you can go on your next adventure in style.
http://bigdogisback.com/downloads/graphic-options.pdf
The Story
Who We Are
K9
Curb Weight
716 lbs Wet
Engine
S&S SuperSidewinder
Fuel Capacity
4.4 Gallons Total
K9 Specs
Pistons Forged
Camshaft 543
1st Gear: 2.94 : 1
2nd Gear: 2.21 : 1
3rd Gear: 1.57 : 1
4th Gear: 1.23 : 1
5th Gear: 1.00 : 1
Starter 1.8KW
GVWR 1130 LBS
Tree Rake 3 Degrees
Make it Personal
Its called sober
