big dog k9 EHC Recall
jmar
Looking for any info on recall for EHC
Contacted Big Dog and they are telling me no recall on 2006 K9
This is my 1st posting
thanks
John
bigkelk9
Well.. welcome.. interesting intro.. ain't gunna be getting a recall done thats 11 years old brother.. sorry bout that..
jmar
It was shutting down a few times then total shut down. Was told Ehc needs replaced. Then was informed this was a recall in 2006
The only recall for 2006 on the EHC was for bikes built prior to march 22nd 2006.
The recall was just unplug the connectors and remove the rubber seal in the EHC ports as they trapped moisture.
Sent from my SM-G925P using Tapatalk
bigkelk9
Really.. almost sounds like an ignition switch.. but need a bit more details and then I'm sure we can help ya out.. and yeah everyone's answer is "replace the EHC, it's bad" and most of the time it's not true.
I highly doubt however that your current issue stems from a recall that is 10+ years old..hell it may have been done
jmar
Thanks I appreciate it. Yes I have done research but I'm not so good at computers, and just always being told about this recall.
I will ck some things out on what was mentioned and let you know outcome
Hirter6Pack
Not Quite A Guru
What do you mean total shutdown? Every thing? No light? No horn? No anything? You going to have to give us a little more than that.:spank:
bigkelk9
Yeah, if u give us a bit more info, my money says we can get ya all figured out.. and that recall wouldn't have saved u 11 years later.. lol.. just sayin bro
Don't matter if there was a recall or not, they went out of business years ago and the new Big Dog guys are not responsible.
Matheny 514
As it's been stated above, there are a few ways to mimic a faulty EHC but most of the time it's actually not the EHC. For example, a low battery will heavily resemble a faulty EHC. Load test the battery and check all connections first before you start throwing money around. Let us know what you find and the load test results.
Big D Florida
This is the best way I've heard, read, whatever...this point made on here, and there are a ton of threads on here to which it is applicable. :old2:
