BDM air ride issue..pls help..
DR_DEUCE
Hi Guys, working on a friends bike. Originally system didn't pressurize. Found bad wire, replaced. 6 months later, system won't vent, found broken connection at vent valve, repaired for now(need new connector). NOW>> compressor won't pump, I found the voltage to the compressor at 9v, battery has 13v. Same voltage off or running. Can anyone give me any insight???
Thank you in advance..
Tom.
DR_DEUCE
No takers..
Here's what I found.. an almost broken wire at the compressor motor housing going to the + brush connector. I disassembled the motor and pulled the wire in another inch, then cut out the bad section and soldered it to the brush wiring. Still not sure why the system provides 9 volts. But it's all working correctly now...THANKS>>
First time seeing this post or I would have been able to help you
I had the same issues on my 06 K9 and had to do the same fix on the motor.
Good to see you got it fixed though.
