claw
About a month ago, I started hearing a squeal from the primary area of my bike. I finally pulled the outer primary and clutch, and discovered the carrier bolts were touching off on the inner primary. I ordered a Bandit and at the time was told I needed a .050" shim to put behind the carrier to ensure I had clearance between the carrier and the inner primary. Bandit says that the tollerances are so tight on the Baker drive that the Bandit carrier will probably make contact with the inner primary as well cause the tranny input shaft flexes under the load. Problem is that my engine sprocket and my clutch sprocket are perfectly aligned with each other now. If I put a shim behind the carrier, then my sprockets will be mis-aligned. Bandit said if I pull my inner primary and send it to them, they will mill it down .050-.100". About a two week turnaround. I got the new clutch today and its like: Shit! I can't even put it in.
Anybody ever experience this? What did you do? Got any opinions?
Thanks.
Thanks.
