baker junk?
Hew guys, have 05 chopper w 15k. Mobile one syn oil and trany every 5k. 4 th gear slipping. Any one had this prob? Fix? Cost? Who in dfw? Thanks!!!
Bobby Schulz
Try to adjust the clutch first. If it still slips you may have a bad input shaft on the trans. Easy to check by taking off the primary cover and see if you have any movement on the input shaft. If it moves the bearing is bad. PM me if you need a rebuild or any info on the trans.
tommy666
Blew my tranny on a 2010 bagger @ 7k miles. Talk to me. Baker told me BDM designed their own tranny's to blow for rebuild.
Thanks Bobby. I dont know much about transmisions, but would seem to me that if the clutch was the prob, would slip in other gears also.
Im pretty sure bd made their trans through 2003 2004. But they clearly say baker now.
Bobby Schulz
allenshawn1, I build quite a few of these bakers a year and have built a quite a few for the members here. The problem is most often the bearing going out. The heli cut gears push the shaft out futher than the clutch apply spring can hold and it will start to slip. In some cases if the clutch is out of adjustment it will only take a little bit to make it slip in 4th gear if there is any play in the bearing at all. Fact is it depends on a few things as to why some of the DSSC transmissions fail within a few thousand miles and others make it much futher. Some of it to do with the bearings used,the input shaft having the proper heat treat, and cut, the clutch basket, shims etc. Feel free to call me if you have any questions at all. 704-989-2294 Bobby Schulz. Leave me a message and I will get back to you.
