Baker Builder in Tampa
vej
3rd gear popping in and out for the second time... last time i replaced trashed bearings and shift forks that looked good... anyone in the Tampa area that can built proof this thing?
farmall
Dogs and slots tend to round off at the same time. I'd yank it then send it to Baker unless wear is obvious under magnification and bright light. I'm buying an LSD OD 6 if I can't find a donor bike first (since a Baker = a large chunk of used donor and I'd get the rest of the motorcycle) and found this on backcut gears, relevant if standard ain't doing it for you:
