Backrest Mt. '03 Chopper, Custom Sissy bar mounts...
bigdogtech01
I wanted to show what I good friend of mine and I have designed and built. We used Steel that he laser cut and then had it chrome plated once cut,welded, ground, and then polished. These backrest/sissy bar mounts are being used on an '03 Bigdog chopper. Customer is very happy with the way they came out. The mounts are made of steel and TIG welded together so they are very strong. Very easy to install over top of your stock rear fender struts. Just remove your rear fender, taillights and wires, slip these mounts over top of your fender struts, run your wires back threw the struts and new mounts, run a longer 5/16" bolt threw the hole for your taillights, and your done.
Will post more pics later. Any questions feel free to PM me.
BadBrad
2005 Pitbull
Nice work! Will you be coming out with something that works for rigids or will this actually fit?
bigdogtech01
Not sure if that will work or not on your bike. Maybe someone else would know? If I had to guess I would have to say no, they will not fit on your bike. but it is possible to build a set to fit yours. I would just need to get hold of a set of struts for your model bike along with the width of your rear fender.
bigdogjohnny
Andrew, thank you for taking the time and effort to help fabricate the mounts! I am very pleased with how they turned out, you guys did an excellent job!:cheers::2thumbs:
http://www.bigdogbiker.com/forums/customizing-add-ons/19315-backrest-mt-03-chopper-cu
Hello I have a 2003 Big Dog Chopper as well, I would like to get a set of the mounts, how much to send to Jacksonville Florida? Thanks Joey 9046464414
