back wheel bearings
got 3 napa bearings today pressed them in and found out the axel wont fit. bearing I took out was marked 6205RS15 napa bearings were marked P62052RSJ . does anyone have the answer?
I guess the 62052RSJ is wrong when it has the J they gave me the wrong bearings. THANKS FOR THE HELP.
The problem is, that there are several bearing sizes for that same number. 3/4'' 7/8'' 25mm, and 1''. The OD is the same, but the ID is different. Some bearing brands have a, -1, or even a, -3/4, at the end of the bearing number, but most don't. I have to explain this to the parts guy every-time I go to the parts house. I have even tried Bearing Headquarters, and spent 45 mins on the phone trying to explain this to a bearing guy. When you go to get bearing, make sure you specify the ID of the bearing.
