Welcome from NJ,my bike just started to back fire threw the carb and wont start
I have a 06 bigdogk9 with the 117 s@s,,,Welcome from NJ,
What bike and engine do you have? A weak battery can cause both issues. Look for minimum 12.8 vdc not running and 14 to 14.5 while running if you do get it to run. If you were riding down the road and the charging system was not recharging the battery, when it got low it could start to backfire. After you stopped the engine it would probably not have enough juice to crank/start the engine again.
If indeed your battery has discharged your best bet would be to have it tested for a possible short. Avoid jump starting the bike if you can but if you do make sure you turn off the vehicle you are jumping from. Possible EHC damage could happen.
Come back with your findings and someone on the site can help you out. All are willing!
If its a carb bike, check the rubber caps on top of the carb. They will dry rot and suck air under throttle. Cheap to replace. Any auto parts store.I have a 06 bigdogk9 with the 117 s@s,,,
When riding down the road the bike will start popping and then just shut down,,so I pull over and hit the start button and it starts back up again but sputters until it shuts down again
It seems most likely a fuel/air issue but it could still be electrical. Do a few of the checks the members have suggested and if you don't find anything obvious drop the bowel and check for dirty jets and proper operation of the float. All free so it just takes a little of you time to troubleshoot if you have basic mechanical skills .I have a 06 bigdogk9 with the 117 s@s,,,
The carb is new,,,It seems most likely a fuel/air issue but it could still be electrical. Do a few of the checks the members have suggested and if you don't find anything obvious drop the bowel and check for dirty jets and proper operation of the float. All free so it just takes a little of you time to troubleshoot if you have basic mechanical skills .
If the problem turns out to be electrical it can be a little tricky but most issues raised on this site get positive resolution without ending up going to a bike shop.
So we are clear, You replaced the carb because of the problem or after you had the problem? What carb did you put on and did you adjust it? These files will help you. Page 20 will show a picture of the proper coil wires.It was be for ,,
