axle grease ?
rijbak
What kind of grease is reccommended for axles installation? Removed both front and rear tires today and changed was not sure on grease,. Any help would be appreciated thx in advance.:D
Tom Chop
Axle Grease
rijbak; On this one I`ll have to agree with Mad Dog. The use of a waterproof/synthetic grease would be a good call here. Even if you try to avoid rainstorms and are sparing of the water at wash time the axles are not easily dried off and water washoff is a really bad thing. If the auto parts shop in your area doesn`t have waterproof synthetic, try and see if any marine grade syn`s are available. they will work just as well. This is a good question and remember not to use too much on the axle itself - a light smear all over the axle is enough. Don`t forget to pack the bearings and if any of them even seem to have a problem REPLACE IT , and don`t forget the seals for a bearing failure with a wheel locking-up is a very, very bad situation. Bearings and seals are rather cheap comparitively. IMHO.
Be Kind
Take Care
Tom Chop :choppersmiley:
