I always purchased the Dyna Beads from Curtis and took my wheel and tire to a shop that could do 300's. I would put the beads in after. No need for them to balance it.I always remove my wheels and take just the wheel to the shop for tire swaps. However, I discovered this week that the shop I have used for years has gone out of business, I couldn't believe how many shops said they could NOT mount a 300 tire(first 5 shops I called). The 6th shop said they could do it but could not balance it, I guess I have been spoiled with the previous dealership(Yamaha/Victory).
Don't know about the 330s but the manual calls for 40 in the front and 42 in the back for the 300 on my '06 K9.I just purchased a Avon 330 tire for the Ridgeback and had it mounted. The only problem is the guy could not get the tire bead to seat all the way on the rim. There is about a 6 inch strip on one side that will not seat. I have tried several tricks with no luck, dish soap and a strap around the center of the tire. What is the max air pressure I should try? Its at 50 psi now. Any suggestions would be appreciated.
Before you try what I said below, let all the air out and push the bead away from the wheel, take some dish detergent and lube up the bead all around the tire and try airing it up again, if it don't seat do it again with more lube, it will go onI just purchased a Avon 330 tire for the Ridgeback and had it mounted. The only problem is the guy could not get the tire bead to seat all the way on the rim. There is about a 6 inch strip on one side that will not seat. I have tried several tricks with no luck, dish soap and a strap around the center of the tire. What is the max air pressure I should try? Its at 50 psi now. Any suggestions would be appreciated.
It should make a loud pop when it seatsHe's talking about max pressure to seat the bead, I have had MFG's in the past tell me they have gone to 90psi on car tires, I wouldn't go any higher than 65psiDon't know about the 330s but the manual calls for 40 in the front and 42 in the back for the 300 on my '06 K9.
