Anyone got a LED rear light to sell?
Ok, so my initial fix of my rear taillight has ceased to work 1 week later even though it worked fine the night I fixed it. The brake and turn lights work, but the running light part of it does not. LED board might need replacing. Wanted to check here first if for some crazy reason someone had a rear LED board for an 05 model lying around. Maybe after an upgrade of lights or something. Let me know if you have one and how much you might be willing to let it go for!
Thanks,
Justin
f-okie
AllGaveSome-SomeGaveAll
I had that same thing happen a couple of months back. Dealer replaced the bulb/board, and after a couple of days it was back out. (brake and turn signal ok). It ended up being a loose connection under my seat. I hope this helps.:flag:
So I fouund some time tonight to troubleshoot the issue a little but more. It is without a doubt the LED board I have. Checked Voltage at the wire connector, 12V...perfect. Tried to connect my 12V test source to the LED Board, and the running light part is out. Middle brake 12V terminal works fine. The board looks kinda trashed for some reason on the 12V constant side. So my beg and plea is still out if someone happens to have a rear LED board, please please let me know. Or can someone lead me to a place with the most inexpensive replacement board???
Thanks,
Justin
CCRainman
Justin, I'll check when I get home on Sunday if you can wait that long. BDM made 2 different LED's. There is the old ones which are discontinued and the new ones. The new ones have more light elements. I'll take a pic or get a number when I get home and you can tell me if it's good or not.
LamboV12
Justin - I'd be happy to donate my two rears for you as soon as Kuryakan sends me my new lights.... won't be any time soon, been on back order since Feb.
Not to go OT - but if anyone knows of any small bullet 3 wire LED's let me know. The Kury's should be plug and play on BDM using stock load equalizer.
I can definitely wait until Sunday...I really appreciate you checking Rain!
Lambo...which Kurys did you get?
One of our other forum members put these on with no issues all he had to do was put the big dog plug on. They come in chrome and black and no equalizer needed.
http://www.weekendconcepts.com/turn-signals-xs.html
