Mario77746
Coming from a Ridgeback that gap in the rear fender is killing me. Has anyone changed the rear fender to minimize the gap? Thanks.
Hummm....sounds like a planYou could always mount the fender to the swingarm to get the fender to articulate with the wheel/swingarm. Im not sure how tough that would be to do but I would imagine a some welding skills and paint would be necessary.
How much does it drop the rear? Got a part number or where to get one?Put a lowering kit on it...you will loose some ride comfort though!!!
So you want stiffer shocks, tighter fender, and lower stance? Why not just go back to hardtails?Ok. Here are a few questions then:
Are there any stiffer shocks that would lower the bike about 1"? I could offset it with 3 or 5 degree trees up front. This based on .2 of an inch drop per degree. I would probably stick with 3 degree trees as to not totally kill the handling of the bike.
If I can't lower the bike I may look at replacing the fender. If I mount it lower on the struts what is an acceptable amount of clearance between the fender and tire? I don't think the full 2.5 inches is really needed.
Thanks.
