here is a website to check for recalls/ service bulletins etc..
ODI - Office of Defects Investigation
This is what comes up..
Report Date: March 15, 2009 at 09:14 PM
Search Type: VEHICLE
Make: BIGDOG
Model: BULLDOG
Model Year: 2005
Results : 9 | All records displayed
Make: BIGDOG Model: BULLDOG
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: MAY 18, 2005
NHTSA CAMPAIGN ID Number: 05V233000 N/A
NHTSA Action Number: N/A
Component: STRUCTURE
Potential Number of Units Affected: 180
Summary:
ON CERTAIN MOTORCYCLES, THE FRONT FENDER BRACKETS COULD FAIL ALLOWING THE FRONT FENDER TO DETACH.
Consequence:
IF THIS CONDITION OCCURS, A CRASH COULD OCCUR WITHOUT ANY PRIOR WARNING.
Remedy:
DEALERS WILL REPLACE THE FRONT FENDER BRACKETS FREE OF CHARGE. THE RECALL BEGAN ON MAY 31, 2005. THIS RECALL CAMPAIGN HAS BEEN SUPERSEDED BY 06V122.
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV.
Check to Request Research. Submit below.
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: SEP 21, 2005
NHTSA CAMPAIGN ID Number: 05V432000 N/A
Component: WHEELS:LUGS/NUTS/BOLTS
Potential Number of Units Affected: N/A
Summary:
ON CERTAIN MOTORCYCLES, THE REAR WHEEL HUB BOLTS COULD LOOSEN AND BACK OUT ALLOWING THE HUB AND BRAKE ROTOR TO DETACH FROM THE WHEEL WITH AN ASSOCIATED LOSS OF STOPPING POWER.
Consequence:
THIS CONDITION COULD OCCUR WITHOUT ANY PRIOR WARNING AND COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REMOVE, CLEAN AND REATTACH THE REAR HUB BOLTS FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 14, 2005. OWNERS MAY CONTACT BIG DOG AT 1-312-267-9121.
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: JAN 20, 2006
NHTSA CAMPAIGN ID Number: 06V019000 N/A
Component: STRUCTURE:MOTORCYCLE KICKSTAND/CENTER STAND
Potential Number of Units Affected: 9726
Summary:
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING MAY STRETCH AND DETACH FROM THE MOUNTING BRACKET OR THE KICKSTAND.
Consequence:
THIS WILL ALLOW THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION AND CAUSE A CRASH.
Remedy:
DEALERS WILL INSTALL A NEW KICKSTAND SPRING FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 17, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: MAR 27, 2006
NHTSA CAMPAIGN ID Number: 06V122000 N/A
Potential Number of Units Affected: 364
Summary:
Consequence:
Remedy:
DEALERS WILL REPLACE THE FRONT FENDER BRACKETS FREE OF CHARGE. (BIG DOG RECALLED CERTAIN BULLDOG MOTORCYCLES IN MAY 2005. BIG DOG REVISED THE REPAIR INSTRUCTIONS AND IS RECALLING ALL THE 2005 BULLDOG MOTORCYCLES. IF YOUR MOTORCYCLE WAS REPAIRED UNDER THE PREVIOUS CAMPAIGN, IT WILL NEED TO BE REMEDIED AGAIN.) THE RECALL BEGAN ON APRIL 24, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: JUL 28, 2006
NHTSA CAMPAIGN ID Number: 06V301000 N/A
Component: ELECTRICAL SYSTEM:IGNITION:MODULE
Potential Number of Units Affected: 2711
Summary:
ON CERTAIN MOTORCYCLES, THE IGNITION MODULES ARE ORIENTED WITHIN THE BATTERY TRAY IN A WAY THAT MAKES THE IGNITION MODULE SUSCEPTIBLE TO VIBRATION.
Consequence:
THIS SUSCEPTIBILITY TO VIBRATION MAY CONTRIBUTE TO A STALLING CONDITION THAT COULD OCCUR WITHOUT ANY PRIOR WARNING AND RESULT IN A CRASH.
Remedy:
DEALERS WILL INSTALL A NEW IGNITION MODULE MOUNTING SYSTEM FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 25, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
Model Year: 2005
NHTSA CAMPAIGN ID Number: 06V305000 N/A
Potential Number of Units Affected: 2101
Summary:
ON CERTAIN MOTORCYCLES, THE ELECTRONIC HARNESS CONTROL (EHC) MODULE CAN FAIL RESULTING IN A TOTAL SHUT DOWN OF THE VEHICLE'S ELECTRONIC POWER.
Consequence:
Remedy:
DEALERS WILL REPLACE THE EHC MODULES FREE OF CHARGE. THE RECALL BEGAN ON SEPTEMBER 19, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: OCT 05, 2006
NHTSA CAMPAIGN ID Number: 06V389000 N/A
Potential Number of Units Affected: 2494
Summary:
ON CERTAIN MOTORCYCLES, THE LONG PIVOT BOLT MAY BEND OR BREAK DURING NORMAL OPERATION OF THE MOTORCYCLE.
Consequence:
THIS COULD POTENTIALLY CAUSE THE REAR FENDER TO ABRADE AGAINST THE REAR TIRE WHILE THE MOTORCYCLE IS BEING DRIVEN. THIS CONDITION COULD OCCUR WITHOUT ANY PRIOR WARNING AND COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE LONG PIVOT BOLT AND, IF NECESSARY, STRAIGHTEN THE REAR FRAME SIDE PANEL. THE SHORT LEFT SIDE PIVOT BOLT AND PIVOT SHAFT MAY ALSO BE REPLACED FREE OF CHARGE. THE RECALL BEGAN ON NOVEMBER 1, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: AUG 06, 2007
NHTSA CAMPAIGN ID Number: 07V356000 N/A
Component: ELECTRICAL SYSTEM:ALTERNATOR/GENERATOR/REGULATOR
Potential Number of Units Affected: 7611
Summary:
ON CERTAIN MOTORCYCLES, A WARPED BUS BAR WITHIN THE VOLTAGE REGULATOR CAN CAUSE A SHORT CIRCUIT.
Consequence:
THIS COULD POSSIBLY RESULT IN A FIRE.
Remedy:
DEALERS WILL REPLACE THE EXISTING CIRCUIT BREAKER LOCATED BETWEEN THE VOLTAGE REGULATOR POSITIVE BATTERY LEAD (B+ LEAD) AND THE POSITIVE BATTERY TERMINAL WITH AN ALTERNATIVE CIRCUIT PROTECTION DEVICE THAT WILL PREVENT A THERMAL EVENT IF THERE IS A SHORT TO GROUND. THE RECALL BEGAN ON OCTOBER 1, 2007. OWNERS MAY CONTACT BIG DOG AT 1-316-219-9129 OR EMAIL TO
CUSTOMER.SERVICE@BIGDOGMOTORCYCLES.COM.
Notes:
Model Year: 2005
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: DEC 11, 2007
NHTSA CAMPAIGN ID Number: 07V580000 N/A
Component: STRUCTURE:BODY
Potential Number of Units Affected: 8061
Summary:
ON CERTAIN MOTORCYCLES, THE REAR FENDER STRUT ATTACHING BOLTS CAN FAIL ALLOWING THE REAR FENDER TO DETACH FROM THE MOTORCYCLE.
Consequence:
THIS COULD OCCUR WITHOUT PRIOR WARNING AND COULD RESULT IN AN INJURY OR A CRASH.
Remedy:
DEALERS WILL REMOVE EXISTING STRUT BOLTS AND REPLACE WITH HIGHER TENSILE STRENGTH ATTACHING BOLTS AND UPDATED WASHERS. HIGHER TORQUE VALUES WILL BE OBSERVED WHEN INSTALLING THE REPLACEMENT FASTENERS. THE RECALL BEGAN ON JANUARY 21, 2008. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
