Another "baffling" question.....
drK-9
So before I remove the baffles on my new to me 08 K-9, I want to make sure it won't cause any motor problems. I am sure this topic has been already beat to death on this forum, but I've been searching all morning and can't find the answer! I am looking to make a little more sound and love these stock V&H pipes on the bike. I can see how to remove heat shields and baffle nut, and it looks like they slide right out. I just don't want to burn the valves or cause and engine harm lessening the back pressure. It is also a fuel injected bike if that matters. Thanks!
Jwooky
Absolutely will not hurt anything. Practically every bike on the planet does so.
Worst case you may want to tweak the jetting for optimal performance.
bigkelk9
Yeah, my bike doesn't have n e and hasn' since I've had it. A little tweaking of the carb will definitely be needed. Good luck
Reddickracing
Fuel injected, you don't need to tweak any. That's what the O2 sensor is for. Take em out, I took out on both my fuel injected Harleys.
SKOGDOG
One of the old ones.
I think if you alter the baffles OR open up the intake, the existing ignition/fuel program will adapt. It is my understanding that the stock map cannot adjust to opening both the intake and exhaust--BDM of course used EPA approved modules.
Run it a while and look at the spark plugs to see if they get too light...
