Nathan1982
Help any one know how to
Align the back wheel on k9 it’s touching when lifted on motorbike jack thanks guys
Sorry have to disagree JR.Measure from the middle of the axle to the swing arm pivot. Should be the same on both sides. If it's still off...your spacers were put in wrong.
You are correct. I should have been more specific. If the spacers are not incorrectly, i.e. the ones with the lips are in the wrong position...you can cock the wheel and not get a correct measurements. I did that once on the Chopper. Sorry. Should have explained better.Sorry have to disagree JR.
Mid-axle to pivot is controlled by the axle adjusters; ie whether the wheel is straight along with belt tension, wheel spacers will control centering (ie inside of fender.)
