Adjure led
I'm about to order an led headlight from wsw. The complete light not the bulb. I was wondering if anyone else has installed this yet. And what are there opinions on its performance against say just the led bulb. I did a search but couldn't find the answer to my question
I looked into doing that too. but I don't have a diamond cut headlight or anything just the stock lens. I was wondering about performance of a bulb in a stock lens vs the complete led headlight. price doesn't matter because in my opinion the more light the better. safety is one thing I don't mind spending extra on..
If your stock adjure is not bleached out, gone from silver to white, then the LED H4 replacement performs very well. Not quite as good as the adjure though. In a quality adjure the bulb performs as well as the adjure.
The only issue with the adjure, and I have yet to figure it out, is the Hi/Lo is reversed. When the Lo bean is on the Hi beam indicator is on.
I spent 5 hours in the dark recently with the adjure LED and kept it on Low beam almost the entire time as the highway would reflect back at me too much on Hi beam. Once off the highway though the Hi beam was really nice.
That's what I was curious about. For me to get a nice adjure lens and the bulb and harness I'm prolly not far from the price of the adjure led.
The High Low is reversed?
Would you not swap the Yellow/White? Or whatever color combo you have?
DogsRUs
What is the BEST Adjure for a BD? For a stock bulb and for the LED bulbs.
Hands down what is the best? What makes it better than the stock lens?
BadDawg Bill
Also, what model # will fit BD? There seems to be many different ones. 7" or 5 3/4?
That's what you would think but when you do that the adjure stays on Hi beam in either switch position. It has something to do with the inner electronics of the adjure. These units are sealed so I don't have time or the money to destroy one to see if I can correct it inside. Plus even if I could it will take destroying the case to get at it so its not really a feasible option anyway.
I wish I had the capital and income to conduct that study but I don't at this point.
I can tell you that the stock lens is designed for a Halogen Bulb to produce the best light pattern and luminance.
With that said I have found that most of the diamond cut clear lenses do a great job of distributing the LED light as well as allowing for the best luminance.
I was carrying some quality adjures but my vendors changed manufacturers on me and the quality and fit went to shit on me so I have pulled them off my site.
As far as an LED light I carry the following two:
LED Adjure
I have this one in my K9 currently and have been happy with it so far.
H4 LED replacement
As far as size goes if you have a stock BD bucket then you are looking for a 5-3/4" adjure.
