Acronyms & Abbreviations
New Boots
Human
I did a search on this and came up with zip so I figured I would post the ones out of the service manual for the new people on the forum without a manual.
A - Amp: Amperes
AMG - Absorbed Glass Mat
AWS - Active Web Services
AN - Aeronautical Standers Group
BDM - Big Dog Motorcycles
BHCS - Button Head Cap Screw
CB - Circuit Breaker
cc - cubic centimeter
CCA - Cold Cranking Amps
CD - Compact Disk
ci - Cubic Inch
CP - Cup Point
CR - Compression Release
C/S - Countershaft
ECU - Electronic Control Unit
EFI - Electronic Fuel Injection
EHC - Electronic Harness Controller
FHCS - Flat Head Cap Screw
HCS - Hex Cap Screw
HHCS - Hex Head Cap Screw
HTS - Head Temperature Sensor
IAC - Idle Air Controller
IAT - Intake Air Temperature
id - inside diameter
KM/H - kilometers per hour
LED - Light Emitting Diode
LG - long
LH - left hand
MAPS - Manifold Absolute Pressure Sensor
MPH - miles per hour
MY - Model Year
M/S - Mainshaft
MPT - National Pipe Thread
O2 - Oxygen
od - Outside Diameter
PCB - Printed Circuit Board
PDI - Pre-delivery inspection
PHMS - Philips Head Machine Screw
RH - right hand
RHMS - Round Head Machine Screw
RPM - Revolutions Per Minute
SAE - Society of Automotive Engineers
SHCS - Socket Head Cap Screw
SS - Stainless Steel
SSCR - Setscrew
THMS - Truss Head Machine Screw
TPS - Throttle Position Sensor
V - Volts
VR - Voltage Regulator
CLEFI - Closed Loop Electronic Fuel Injection
ETS - Engine Temperature Sensor
DTC - Diagnostic Trouble Code
AFR - Air Fuel Ratio
:flag::flag::flag::flag:
