A couple of issues with my Dog
Dlandbob
First one is with the left rear tail light wires, my bike bottoms out on the fender and has worn them to bare wire. I have replacement wire I will solder on but is there something I should do to keep this from happening again? Maybe my rear shocks to whatever, it has been a Major issue since I have had my bike. Second thing is I have the D&M Daul Air Cleaners and the breather bolt on my front head keeps falling out. The little breather bolts are 69.00 each time I have to replace them and it's Getting Old! It's nothing I have done wrong, I had a shop install them. The first time I installed them, never had any issues, I took it into a shop and he had to do something to my carb and that's when I started having issues. The breather bolt broke off, so then I paid another shop to get the broken part out of my head and put a new one in. Well a month later that came loose, if that. He stripped the alen head by tightening it back in so I kept a eye on it but that came off too. I have 4 breather bolts but they don't fit my heads, it was just extra in the kit for different heads. I am not sure what to do about it. My main question is, it's ugly but I have a small piece of duct tape cover the hole on the outside, will that cause any damage or performance issues? My air cleaners are on good, the washer between the head and air cleaner keep the air leak less than wide open along with the duct tape on the outside so is that a problem at all?
nine lives
On your bolt problem, you can drill a small hole through the head of the bolt, horizontally. Then insert a small wire through the hole and attach the wire to another point, did this on my dirt bikes, works well.
