99 Vintage Classic wiring diagram.
Michael Gill
Just picked up a 99 and the ignition was shot. I upgraded to an S&S HI4 and its running great but the run/ stop switch is no longer working. The S&S HI4 has its own wiring and cut the switch out of the system. Does any one have a schematic or manual in pdf for this model? I would like to correct this issue for safety. Thanks.
FrankBDPS
Where did you pic up the hot wire to feed the new ignition? If you have a Thunderheart harness controller you can go to their website and see a wiring diagram. Seems like you just did not get the correct wire from the switch or controller hooked up to feed the new ignition.
Michael Gill
I had to jump of the ignition switch. None of the 3 wires (red, white w/red, and yellow) leading to the original coil had power with KOEO. I'm sure I could find the interupt but would like a schematic to be sure entire system is proper.
