Coming up on the 5,000 service. I noticed the manual said to adjust the clutch & lube the pushrod.
I assume you must remove the exhaust to pull & lube the pushrod.
Is it worth doing @ 5,000 (Clutch works fine now and I was just going to adjust slightly) ?
Thanks in advance.
