4th gear slipping
Betabquicker
Hi all. I need some information on my 06 mastif. I have owned it since near new only 500 miles. I bought it in 2007 from Idaho and shipped it to New Zealand. I have had problems with 4th gear slipping most of the time I have owned it so it has only done just on 11000 miles. Seen as 4th is the main gear I tend to just ride my my v rod instead. So what causes the 4th to slip. The gear box is mint I have had it out and apart and back in and it was good for a couple of rides then slipped again. I just want to ride a hassle free bike. Please help
Mickmorris
Well Known Member
Have you checked the shifter pawl to make sure it is set correctly?
Mikeinjersey
Because you have had this problem virtually from the start, your issue is most likely a clutch failure. If your problem was in the transmission it would be missing shifts , popping out of gear, audible grinding etc. You state that your slipping is in 4th but I'm fairly certain 5th and 6th would be even worse.
A maladjusted clutch will slip under load. Another possibility ( less likely) is that the original plates were installed incorrectly. Because you have 11,000 miles on a clutch that has been slipping, it should be replaced.
You could try adjusting it first . These files will help you.
Betabquicker
Hi. Thanksl for that but I don't think it is the clutch as it only does it in 4th gear under load and its not constant it is like its jumping a tooth on the cog or something. If I want to thrash it I give it heaps in 3rd then junp to 5th no slipping at all in any other gear. The only other issues i have ever had with it and I don't think that would affect it, is the main swing arm bolt sheared when I took off. That was when I first got it and I have gone through 3 sets of exhausts from vibrating and the hose clamp bracket breaking.
I think I will try the shifter pawl before I do anything else. Is there anything I need to know about that . Thanks
Mickmorris
Well Known Member
Needs to be checked in 3rd gear.. It is easier to do with the top cover of the transmission removed. There’s a good video on YouTube from Baker Drivetrain’s .
Mikeinjersey
Your latest description Leads me to be thinking your problem is inside the transmission. Assuming you have already checked your drivebelt for worn or missing cogs and worn rear drive pulley. Check out the page 7-1 of the transmission pdf. It shows that the sliding member/dog is engaged into the 4th gear when in 4th and it is engaged into the 5th gear when in 5th. In all other gears it is centered and not driving at all. Considering your symptom, a slightly bent 4th-5th shifter fork preventing the dog from fully engaging the 4th gear is a probable cause. Less likely, but of course a possibility, the sliding member/dog or 4th gear itself could be worn or damaged. Both possibilities could be true since you have had the problem from when you first got the bike.
