2011 K9 ?3-pin?
New Boots
Human
I've been looking over the site and my stuff don't match very well - one red and two clear lights is all i have, what am i looking at here? (S&S Supper G Carb)
PaulHart
Thats the Ignition module. You have a 2011 and I'd bet you have the newer PDM electronics in yours. So the EHC threads will have nothing to do with you. If you have a fuse box with fuses and relays under the seat you have a PDM. AND BE HAPPY YOU DO.
V
Paul is correct, but the key must must be in the on postion and the run button pushed. Then look at you ignition lights. Also would be good to know if you have a EHC or the newer fuse box. Search EHC and you will get many pics of one to compare.
You might check the battery trminals for tightness and if the bike is runnin okay put the seat back on and either ride it or go back inside tha house. :D
New Boots
Human
Thank you V, I was just trying to figure out what exactly I have. Nothing is wrong with the bike. I feel the need to be educated as to what I do have and I’m taking advantage of the forums knowledge. I do appreciate each and every post. :cheers:
