2010 Bulldog just shuts down!
erldawg
Cool to hear. Thanks for posting the fix..
I thought the angle sensor was in the fuel injection ECU. I'll revisit the manual..
ksmike
I have learned more about the EHC than I cared to. I belive only the EFI version of the EHC has a bank angle sensor or (tip sensor as its referenced in the manual)
Also some other things that the EHC do....such as turn signal cancel , which is programmable if you have the software. (which I don't) And did you know that the turn signals don't cancel if it is the bike is in neutral? (input from the neural light)
Also the EHC controls when the spedo shows low RPM (below 1,000) and flashes....at least on mine. Don't know about other models. I have my idle set to 900 so it does flashes alot.
