Try to start up my K-9. It wouldn't start, heard clicking noise by starter. Check voltage on battery found it to be ok. Check volts coming from green wire which is connected to starter area, only had 8 volts coming from battery. Does this mean that I need a new computer module? Any suggestion or advise would be appreciated, thanks.
It needs at least 12.8 volts to start. If battery voltage is 12.8 or greater then check all your connections at the battery, starter and don't forget the ground wire at the starter mount. If all this checks good then you may need to clean your starter solenoid contacts.:up:
