BigDogBro1
Made in the USA
Hi Guys,
Engine died while riding. Will crank but no spark.
I found one of the ground wires in the three wire braided connection bundle to the frame next to the battery on the right side using a 1/4" bolt/washer.
One of the crimped fasteners had broken off at its neck section.
Will check all the obvious: Battery, connections, wire, relay, crank sensor, coil, etc..
QUESTION: What are those THREE ground wires providing GROUND to?
Thanks.
Thanks.
