2006 Ridgeback Owner & Service Manual
Utopiapga
Thought I had these but just noticed that they are for the 2005!! And as we know the 2005 is way different then the 2006 so if anyone can help a brother out please give me a shout!! I need to do some maintenance to my dog before I take her out this season!
Thanks!!!:cheers:
05 and 06 cant be any more IDENTICAL actually. I can't think of a single change.
You are all set with the manual you got.
Utopiapga
I know they had alot of issues with the 05 just didn't know what or if any changes where made in 06.
BBChopper
Supports 2 Disabled Vets
05 and 06 will be the same. 05 there where three different frames for the Chopper not sure about the Ridgeback...
Oh there was a change to the carrier, 06 should be the new one.
V
06 should have a G carb stock vs. the 05 E carb. Then there were just some tech bulletins as far as I know of on VR's and stuff.
Brew
Yep restrictors with super E carb, old clutch carrier. I believe they both have the trans main shafts that have been breaking. Still hot looking scoots...:D :2thumbs:
Yes I definately Have the Super G Carb
The Carb is the same from a repair manual standpoint. So nothing to worry about there E versus G.
The E was designed by S&S for engines with <100 CI's. Whereas the G is for Larger.
They used the E on the 05's for EPA regulations to choke the motor and run lean.
Utopiapga
Yes I got it thank you for all your help! :cheers:
