2005 RIDGEBACK REAR
Lifwghts
BIG BASTARD
Question.........I currently have a 300mm rear tire on my 05 Ridgeback; do I have enough rim width/clearance to install a 330 rear tire?
Thx all
:flag:
The 330 tire is about an inch and a quarter wider. I don't believe it's going to fit. Plus you would have to extend the trans pulley out also.
Matt Moore
I don't think it will work on your Ridgeback without major modification. Avon is the only company I use (and know of) for the 330 tires. Not only is this tire wider, it is also shorter (made for a 17" rim). You will also have to consider your drivetrain's offset to get proper belt clearance/alignment.
Brew
330 will not fit! A 300 Metz is very close but will fit fine. Running a metz on mine also... :D
