2004 mastiff drive belt size
Bigdogbob
My 04 mastiff has 130 tooth 1 1/2” wide belt book shows it being 130 tooth by 1 1/8” Has someone changed the belt to a wider belt? I have been thinking about doing a chain drive conversion now that the belt is broke needing to know what the offset of the sprockets are if anyone has any information it would be greatly appreciated
I did a quick search on here, on chain drive conversion. It's not something that popular on these bikes, because the belt is so much smoother. Give Eric a call, and he can fix you up with the correct belt. 620-680-0395
Bigdogbob
You can do the same thing with an open primary. I did that on my 03. I lower the ratio for a faster start, but the problem I ran into was, I was looking for 6th gear at 65.
Bigdogbob
With chain pull wheel change sprocket you can have different length chains for each sprocket. Ratio changes in less than hour
