THanks 2 you all!! I had the bike out yesterday to Ride to Big Dog of Tampa and the thing Cut out 1 mile from my house and it is a 1 hour ride to Tampa. Pulled over to a jiffey lube and borrowed some tools. My buddy had a 06 ridged and he went to get that di-electric grease. I greased the hell out of the ground that was smoking on the battery and I rode all day with the bike running like a top... When we were cranking it the ground was smoking??? n Is that normal or do you think that grease could have fixed the problem??
Thanks again!!!!
givin up that quick?pull your connector to the ehc make sure no moister and fill it with die electric grease.i just replaced my right hand control board,the brake wire wore through some time ago and was shutn the bike off but would restart.i just cut the wire back then and just got around to fixn it.you also said no fire,do you mean no fire to the plugs?
