Happy to say I can positively answer the mystery once and for all as to the length of the clutch cable for a 2004 Chopper. It's 65.5" from cable fitting shoulder to cable fitting shoulder. I removed and measured my stock cable. I have a 2004 BDM Chopper RT, 107 LHD. My measurement is the exposed length of the braided cable casing you would see upon inserting the end fittings into the clutch cover and into the clutch lever, and with the cable lengthening adjuster fully bottomed out to the shortest cable length. My measurement is NOT the end-to-end measurement of the wire cable ends as that would be longer. The eye connector on the end of my cable split open inside my clutch lever body thereby detaching the wire cable. Donna at HDM, Inc. shipped me a 67" cable that "The Rookie" said would work. Eric was absolutely correct. It works great! The cable I received from Donna measured 67" from shoulder to shoulder. Rather than following the stock cable path which is above the forward control I ran it beneath the forward control as advised in a post I read from Wildsteedworx. Running below the forward control gave a slightly larger and smoother bend radius. It hugs the bottom of the forward control frame studs and won't scrape pavement. My clutch cable operates smooth as glass, I think smoother than stock. Thank you Donna, Eric, and WSW Chris for the advice!
