The_lush_one
So who has a 2002 Pitbull? And what parts I.E. grips, pegs, pips will fit. Everything says takes Harley parts which Harley Parts.
Thanks up front.
Thanks up front.
Is the above true for a Mastiff as well as a Pitbull? I am getting the itch to change some thingsLush, you can get anything from a softail and it'll fit your bike. The grips are 1 inch. You can order forwards or just pegs. Just make sure they are for a softail. Your forwards are made by Thunderheart. You can get mostly any pipe you want just make sure it's for a LSD softail. Sometimes you might need to fab a mounting bracket. Hope this helps
Yes Jerry, they are the same except for the suspension.Is the above true for a Mastiff as well as a Pitbull? I am getting the itch to change some things
Jay, you should have standard H-D stuff on your bike. They didn't start the proprietary stuff till 04.What about for an 02 Bulldog
The pegs are standard softail forwards. As a matter of fact they are made by Thunderheart.Sorry, you are incorrect. Pegs will not fit even close without extensive modification. I have tried.
