P pumpdogs Member Mar 19, 2011 #1 What type of oil do you use for an oil change on this bike and how many quarts does it take?
W woodbutcher Mr. Old Fart member #145 Staff member Mar 20, 2011 #3 oil--amsoil, mobil 1 synthetic. trans--spectro, redline heavy shock. primary--non-synthetic (syn. tends to cause slippage) no answers because that question has been asked and answered hundreds of times already. try using the "search" function in the tool bar above.
A Apache New Member Dec 11, 2013 #4 how many quarts of oit and what type for oil change on a 2005 big dog.
pauldeepsea Guru Dec 14, 2013 #6 Apache said: how many quarts of oit and what type for oil change on a 2005 big dog. Click to expand... Not sure if you found your answer but I use Mobil 1 synthetic 20w -50 and usually between 2.5 - 3 quarts On another note when you have the oil drained from the reserve and the oil filter removed start the bike at idle and drain the oil from the case
Nukeranger Nukeranger Dec 14, 2013 #7 Also, get a scavenger unit from Mad Dog to get that last quart of dirty oil out.
