2001 Mastiff rear wheel spacers?
riffraff01
I need info on rear wheel spacer order and position. I had a new tire and wheel bearings put on, and now my wheel is off center to the left...can anyone help with the order, a picture would be great if you can get one, if not the order per side would be a great help...thanks a bunch if you can help...
riffraff01
Thanks for the response...yea i can post pics, but got to get it out to take them...give me a few minutes to take them and figure out how to post them..
riffraff01
It looks good i have the tool to check it and measures right, but looks about 1/16 inch or 1/8 inch off center in fender. Rides good and space between tire and belt looks about the same as it was before...
FrankBDPS
Sometimes people who you think should be more carefull than what you would be yourself just are not. Line it up and make sure the belt runs true. Go ride.
Spacers look to be in the right place.
But you never know.
I just spent several hours straightening out a customer's 08 Mutt where someone had changed wheels but did not take the time to adjust the spacer size or make sure the bearing preload spacer was the right length.
