Mastiff Rider64
Hi guys and girls, I was wondering if I could pick your brain a bit. I have a 09 Bagger and about two months ago I got the dreaded check engine light. I bought a laptop put Protune-II software on it and read my codes. I found that the only code I was reading was the Rear Adaptive Limit Max P0173. Now what the bike did before the check engine light come on. After a day of riding, with stopping for lunch and some shopping up in the mountains of N.C. at Lake Lure, on the way home I had noticed the oil light flickering a bit, never staying on for more than 2 seconds. I had just did an oil change the night before the ride. But as I turned off a 4 lane highway on to a side street one block away from my house I gave it a bit of gas and the bike hesitated and coughed thru the EFI system and the light came on. Any time I tried to give it gas more than 50 percent throttle the bike died, kinda like a weed eater when you choke it while running. and if I let off the throttle the bike would come back to life and start running. So, I get the bike home, call a shop after I found my code and talked to Mr. Wright and Andy that use to work at Big Dog. After telling Andy what happened and the code, I had him explain it to me. I took my bike to a repair shop that use to be a BIG Dog dealer. Well I told them what code I had and the previous codes also which I was told was from probably earlier this year when I had the bike worked over and had parts chromed, diamond heads and powder coating done to the heads and all. After 2 weeks from hearing nothing from the shop I called them. The mechanic told me that he didn't come up with the same codes that he got a bad O2 sensor and a high air temp code. So, finally after another 2 weeks I get the call that they changed the O2 sensor, tested the bike and looked it over and he rode the bike no problems come get it. So when i get there my bill is 300 dollars and I'm on my way home. Well on the way home I am going down a hill and I go past 50 percent throttle and the bike dies. Another way to describe it is when your are in your car and speeding and you hit the top speed the computer will let you go before killing the gas to the engine. But the check engine light dont come on, so I think I'm out of gas to a degree cause when I got stopped by a red light, the bike cut off. I waited til it turned green, cranked the bike and stopped at the first gas station about 300 ft down the rode. Took my gas cap off and wow its full of gas??? I crank the bike and drove home with not another issue. I mentioned it to the mechanic the next day as I'm dropping my other bike off. he said the motor was probably just cold and not warmed up. Really? Hmmmm. So, Last weekend on Saturday my girlfriend and I are out riding and we are on a 4 lane highway, I turn off of it and go to get into the throttle and low and behold it hesitates, coughs thru the EFI and boom check engine light. Now I start to realize after a few miles and a few stop lights later that I have no power past 3000 RPM's in first, drops to 2600 in 2cd, 2000 in 3rd, about 1800 in 4th. I was a little further from home so I got to actually pay attention to things this time. Well about a mile from home and I'm sitting at a red light and when it turns green, I kinda get on the throttle and the bike hesitates a second and then I'm over 3000 RPM's and the bike is running fine. By the time I got home the check engine light is off. Check the codes no codes no past codes???? Sunday went riding again this time to Ceaser's Head in S.C. almost a straight shot for me, mainly one road 42 miles of 2 lanes in the country. @0 miles into it bike had run fine no issues. Then I went to pass a car on an up hill grade and when I down shifted and rolled the throttle it starts hesitating and then losing power and boom check engine light. Stopped at first gas station 12 more miles down the road got gas and started the bike and kept on going, 2 miles down the road check engine light goes off and bike runs fine. On the way home 5 miles from home I turn on to a 2 land road go to get into throttle check engine light again no power past 50 percent throttle or above earlier mentioned RPM's. As I'm going down a 4 lane highway I get the throttle to the point it starts acting up and played with it there a few seconds then the bike cleared up check engine light went off and boom off we go. Get home no codes no past codes.
So what do ya''ll think the actual issue could be?
This is the codes I got before taking the bike to the shop on 8-9-19. They had it 4 weeks and said they got a bad O2 sensor code and changed the O2 sensor.
