07 K-9 Tries to Start but won't Turn Over
BigMack73
High-Tech RedNeck Rider
07 K-9 Engine is Hard to Start and/or Locks Up during Start
Have an 07 K-9 bought in late Summer 2006 that has historically had some Flaky electrical woes, but now is developing into real problems NOT-Starting, and cutting off while running. I have scoured the Threads, How-Tos, here in the BDB Forums but just have not found the answers I need to resolve! Hope I can explain and get the 'next step' help...
Few things about me:
1. I do Field Service, Electronics (former US Air Force Computers geek), BUT, although I used to work on all my trail bikes and dirt bikes growing up, I DO NOT like touching my K-9 big V-Twin but understand the concepts of repair.
2. My long time Big Dog Dealer/shop I had all previous repair and maintenance work done has closed down, have not figured/found a new place to take K-9 for repairs in the last 3-4 months!
3. Looking to start trying obvious repairs, connections, easy part changes first to eliminate paying for simple stuff. Guess I need to "Take Charge" of my Dog... (Stop being a pussy in other words!)
History of Bike Repairs:
K-9 has always had sluggish starting issues since purchase. Bike tends to turn-over very slow especially first crank, often stopping dead in first half second of turn-over like pistons hit a wall. Many times this followed by split second horn beep and idiot lights four-way lights flashing. Worse in cold weather below 55 degrees, luckily I live in Florida, not a problem but 2-3 months at worst! K-9 almost NEVER starts on cold morning below 45 degrees.
- Usually Turning key off, back on, waiting a few seconds seems to clear and she starts OK.
- Big Dog dealership swore to me Battery OK, Compression Releases OK, Starter OK, Ignition OK. I would badger them when I brought it for servicing (mainly worried that I wanted to get these repaired while still under Warranty if needed).
K-9 has ALWAYS had original Speedo issues, random days either 'N' or Oil light would stay lit or come on at wrong/incorrect times, Speed Needle would either NOT work at all, oscillate erratically +/- 10-15mph at steady speed, or stick around 30-45 mph. Various times Miles Odometer will not clock up new miles.
(Only good thing is, I have about 11,500-12K miles driven on a Bike that shows 4996 currently... HAHA).
The above have been my constant "companions" for the past 5.5 years with my girl! On many days riding I have no issues at all for 5 years, then on some days she is like the Excorsist and her head spins around. Dealer refused to ever change the Speedo, seeing as it always seemed to 'work fine' when I drove it in for oil change or maintenance. Later I realized that the enormity of the Big Dog Speedo issue was that they were never going to resolve it!
- I have had K-9 on a Battery Tender since the first day brought home. It was on the orginal factory battery until just a week ago, still the same Tender Jr. as well. Even though every time I brought it to Big Dog dealer for issues, they always lectured me that I needed to keep the battery fully charged and all my issues would go away. I would remind them of the over-priced Tender Jr. they sold me! (79.95 when I found I could have bought it anywhere for 30-40 dollars less... OK, so I was a Chump! HAHA). But, it stung to be told it was my fault for not charging a battery when YOU sold me the GD overpriced charger!! Just sayin...
Major repairs (other than oil change/tune-ups):
1. Voltage Regulator repaired under warranty/recall Fall 2009 (said mine had a VR from a known potentially defective batch?), this seemed to help with the sluggish starting woes and at times the problem I took it in for which was re-starting K-9 if I had only ridden for less than 15-20 minutes. VR seemed to resolve these issues, but NOT the Speedo flakiness, random Cut-offs while driving, nor the NOT-staring at all below 45-50 degrees F.
2. Problem Shifting. Shifting into Neutral Fall of 2010. Took K-9 in for repair, found that during last tune-up someone had replaced a linkage bolt with one that was too long, bolt had ground a rut into my primary (something like that) Dealer replaced all that and repairs under warranty due to their negligence. However, when I drove away from dealer, got 4-5 miles away and Bike cut off completely. No key toggles, nothing, dead. Dealer came and trailered bike back, had it 2 weeks, found problem was Ignition Module?
- While there so long had Dealer install Low Pull Clutch (GREAT Upgrade!!)
- Someone at dealer accidentally tore hole in paint on my tank, dealer sent for local re-paint/repair. While there, found threads on Gas Cap had sheared out, replaced my Gas Cap with Newer type with Click relief to prevent over Torquing.
End result that is pertinent... New Ignition (whatever was replaced), seemed to give me the most error free riding year of 2011.
Dealership closed in Winter 2011 and I got 5000-7500 mile servicing done (hard to tell since my Odometer has ALWAYS been intermittant! I tried to explain to them it was most likely more like 10K servicing...)
Since that servicing, the bike came back and started the current issues, but, I have no where to take it back to since they closed.
CURRENT PROBLEM: Engine is Hard to Start and/or Locks Up during Start.
When I turn the key, all indications are OK, Speedo goes through its start-up pattern, etc. Wait the usual 2-3 seconds, then hit run button. No throttle (ever, never have needed it on cold start) nor Enrichener knob. Hit Start button, and hear/feel starter engage and cylinders start to turn-over then Stops dead like the pistons hit a wall! All lights flash on Speedo, and many times the horn will emit a split-second beep.
Try recycle of starting routine, Key Off/ wait 10-15 seconds. Try it all over Again.
At first 3 out of 4 times on the second try it would sluggishly turn-over and crank like normal.
It has done that for about 2-3 months off and on. Now it only starts about 1 out of 4 times. The 3 of 4 unsuccessful Cranks I retry starting it 5-6 times before I can tell the battery was now running down (from the lack of vigorousness in the initial half turn of the crank) and then would have to put the Tender back on to re-charge the Battery.
Had Biker/rider friends who were mechanics give me advice. Several (including from my experience reading these Forums) suggested I was LUCKY to have gotten 5.5 years on my original BDM battery given the history with VR and Ignition Modules going out. So I thought hey, buy a new battery!
1. Bought and Installed a new TruGel Battery MG20L-BS, got it through a friend for just over $100, I charged it initially with my Schumacher SC-1200A charger I use for my Fleet Work truck Gel battery (it has a Gel Battery mode). Took the big step to install it in the Big Dog myself and WHAM! same symptoms... (Yes, I was really expecting to fix this myself, the 'old battery' sounded like a great starting place, and the new TruGel has 30-40 more CCA, all of which sounded really great!)
- Placed K-9 New TruGel battery back on charger, came back later in the afternoon and this time tried manually pressing the compression releases before cranking. This time the K-9 did start up fine, a little sluggish as usual, but cranked right up on the second turn over like always when it cranks, wife and I rode to one of our favorite spots to eat about 25 minutes drive. I am thinking, OK, must be issue with compression releases, so I am OK. Wife and I get on bike to leave and symptoms return! Tries to crank, turns over half turn stops/locks up and lights flash (although NO horn beep this time), even trying manual compression release did not help.
- I accidentally tried to crank it the 4th time thru my routine and did not get clutch pulled in while bike was in 1st gear. K-9 leerched forward about a foot (as it does if I am stupid and leave bike in gear while cranking...) best part of this stupidity, the next time I recycled Key Off/On usual start routine, she cranked right up like nothing had happened. Noticed though that on the entire ride home Speedo was working BUT, noticed that Odometer had clocked NO miles at all since leaving home. Knew this cause left home at 4996miles showing and thought to myself "the K-9 with 10K miles was FINALLY going to turn over 5K"!! Got her home, put it on the charger and it said the Battery was at 64% level. Thought this was odd since I had been driving for almost 25 minutes since cranks, but, had cranked it a lot at the restuarant.
2. Today I tried visually checking connections around my Starter, cables leading from starter to ECH/battery, checked ECH connectors for water, most appear sound to me, but for a Broadband Field Engineer, I SUCK at big V-Twin repairs! HAHA
3. Today I also tried starting it again, K-9 would not start, same symptoms. Only turns over about half crank stops dead, lights flash, again today No split second horn beep. Tired cranking process 6-7 times, noticed cranking vigor going way down, stopped, placed Shumacher charger on TruGel it said it started around 49%.
So I am wondering what the next steps should be?
Here are a few suggestions biker mechanic buddies gave:
1. New TruGel battery could be weak/possibly bad?
2. Problems with Compression Reliefs on S&S Engine?
3. Potential Shorts, Connection, Wiring Harness Issues I can not easily see.
4. Problems with Starter/VR/Ignition drawing down Battery on initial Crank. Also contributing to possible lack of charging properly while driving?
5. Problems with ECH not sending Voltages where it needed to be!
All sound reasonable, especially given the history of this 07 K-9! When she runs/cranks OK she is a dream (like Nothing ever happened bad at all). When she bites the hand that feeds her, she is a flaky, poor starting, inconsiderate bitch....
Problem is I can't trust the K-9 now to take wife anywhere. Missed Daytona Bike Week scared to get away from home and be stranded!
Please help! Suggestions on next things to check, that I could try, else next step is for me to find a new shop that will repair Dogs!
Thanks,
Gary "BigMack" Mack
Williston, Florida
claw
I've had the exact same issue twice in the last 3 months. First time it was loose connection on the negative battery terminal. The second time, yesterday, loose connection on the positive battery terminal. Make sure the battery is good, and the connections are clean and tight.
I echo this guys recommendation, clean the battery terminals and ensure they are nice and tight.
After that, since you rode it and it was down near 60% I would check to see what the volts are while the bike is running. You should be in the neighboorhood of 14.4-14.6, If your not you may have an issue with your charging system. I would start at 4. and rule that out first as it seems that all of your problems in getting the bike to start revolve around a low battery.
4. Problems with Starter/VR/Ignition drawing down Battery on initial Crank. Also contributing to possible lack of charging properly while driving?.
Start Here ^^^^^
Bwhitt
Just had the same problem with my 07 k9... New battery fixed it..... Now I have other problems with is smoking, but it has been settting for two years..... But, I would double and triple check the battery.
BigMack73
Thanks for the suggestions so far! I will check the Voltage to battery while running (if I can get her to crank!) and report back.
I did just buy and install a brand new TruGel battery before Daytona Bike Week about week or so back, and had cleaned the contacts of all the + and - connections during that battery re-install. On Sunday morning I did hit both terminals with the ole #10 wrench just to make sure they were tight during the last visual insepction. But, I will check those again to be certain!
If I suspect the brand new installed TruGel battery is bad from factory, is it best to take it out of the bike and hand carry it to a shop to load test the battery? Or if I can get the Bike cranked and drive it to a place is that better/easier for them to test it while it is in the bike?? (Havent had battery problems in any of my vehicles for years... sorta green on what is best now!)
One friend this morning had e-mailed me to try Charging and re-installing the original BDM Battery (since new battery did not help) and see if problems turning over get back to original poor cranking (as it has gone from not cranking 3 of 4 times to Not at All!). That may indicate the new TruGel is NOT delivering the CCA it claims.
Thanks! On the road today for job, when I can get back home and try suggestions I will report back to Forum. :up:
BigMack73
PLEASE HELP?? 07 K-9 Still wont Start consistently!
UPDATE to Issue:
Was able to get home before dark this evening, checked a few things on the Dog...
Could not get her to crank over at first, had bought some Mobil 1 Cycle Sythn 20W/50 and topped off the oil tank, noticed it was just barely touching the end of the dip stick.
Bought some new AutoLite 4164 Plugs to swap out (been a while since changed).
1. While I had the Plugs removed, took the Charger off the new TruGel battery and gave her a crank! K-9 turns over just fine. Seems Starter and battery can easily turn it over with no compression. Added a few shots of Carb Cleaner into each cylinder, just for good measure and turned it over a few more cranks.
2. Took off the battery compartment side plates so I could access all the connectors again, inspected around did not see any that looked worn at contact points. Removed the Neg and Pos cables and connectors and struck them all again with contact cleaner paper, then re-installed all making sure all were seated flat, and tightened them both back with the #10.
3. Tried to crank the K-9, the usual one big Starting crank CLick, then Lights flash (no horn beep).
4. Tried again, this time added pressing the compression releases on each cylinder, again, CLICK... Lights flashing (no horn beep).
5. Decided to try one last time cranking, Turned on Key, waited for Speedo to do its thing, counted a few seconds, pressed Compression Releases, Hit Run, Cranked right up! (But, I am skeptical because that basically fits the one out of four attempts are successful symptoms...).
Took her for a ride for about 20-25 minutes, she ran OK. By the time I came back it was dark.
Before turning off the K-9 Checked Voltage to Battery (while Running):
Only 13.7 - 13.8 Volts!!
Apparently I may have problems with the charging system??
To check the new battery, turned her off and let her sit for about 5-8 minutes (typical of my gas up stops...).
Tried to crank her up, CLICK, Lights Flash (no horn beep). Will not start, same symptoms.
Placed the Schumacher Charger back on the battery, it settled at saying the battery was only 36% charged??? WTF?
Any help or suggestions? Please?
My thoughts:
1. New TruGel Battery sucks...
2. K-9 appears to have charging issues while running?
3. K-9 seems to have severe Compression/Friction issues or something drawing down battery during normal cranking.
I am thinking of placing the original BDM battery back in place, and having the TruGel load tested?? Is this a good move?
UPDATE to Issue:
My thoughts:
13v range it what the battery should be giving off without the bike running. I would say theres a problem with the bike charging. I would start with that before figuring out the compression release issue, as it may be more apparant due to a weak battery.
You can just go ahead and remove it from the bike and bring it to Walmart or AutoZone and have them load test it.
UPDATE to Issue:
You can just go ahead and remove it from the bike and bring it to Walmart or AutoZone and have them load test it. I would also have them run 2 or 3 seperate tests just to be sure. Mine as well bring your BDM battery too! Get them both tested and see.
ringo
if battery voltage is 13.8 or below( enine running) flow chart says measure voltage at both ends of circuit breaker and if a difference is noted reset breaker. If that looks OK it sends you toward the voltage regulator, then on to the stator/rotor.
Do you have a service manual?
BigMack73
I am going to take the week old new TruGel Battery out and have it Load Tested! Tomorrow (Wednesday) if possible.
I do not have a full 2007 Service Manual. I have pieces of the 2008 Manual and T-shooting Diagnostic Flows. I also have a printout of the ECH LEDs lights (which I believe I got from this site years back).
-I think I have Chapter 13 (Electrical?) and Chapter 14 Troubleshooting of the 2008 Manual, which I got some from here, and some from friends trying to help me with the flaky electrical issues I've had in the past.
I am thinking if I continue to try and maintain my K-9 I need to invest in the 2007 Service Manual!
I had another Big Dog rider (06 K-9) friend tell me that I need to refer to my issue as 'Engine is Hard to Start and/or Locks Up during Start' so as not to confuse you guys.
- He said that a 'Hard Starting' or Locking Up engine 117ci can draw/drain any battery down to well below 60% level after multiple crank Attempts. Is this valid info??
- If this is valid, maybe my original BDM battery OK, just being drawn down by the Hard Start/Locking during starting issue. I still don't trust the new TruGel Battery though.
- He also said that his issue was similar (intermittant hard start/lock) and was an Ignition issue?? (Mine has had Ignition problems before from a faulty VR...)
Where is the Circuit Breaker located? And what is the procedure to reset it? NEVERMIND, FOUND IT HERE:
http://www.bigdogbiker.com/forums/179323-post14.html
Will the 2008 Manual Info be close enough to get me where I need to go for Troubleshooting flow? I understand t-shooting flows, my problem is I may not understand where/what to look for when it says "go to the circuit breaker Terminal B-1" etc.
THANKS FOR HELP! (I am beginning to believe it is time for me to locate a Real V-Twin mechanic and take it to a professional! HAHA)
Next: Remove new TruGel battery have it load tested. Try troubleshooting flow on the Running Battery Voltage measured is Below 13.8! It mostly hovers around 13.6 to 13.7 volts at the battery when I tested with a good Digital Fluke TruRMS MM I have for my job.
BigDogBro1
Made in the USA
Make sure the compression release solenoids are both functioning correctly.
1. Remove both sparkplugs.
2. Turn on the key.
3. Place your finger over the top of the CR cover bulb and push downward until you just feel the top of the CR stem.
4. Leave your finger in light contact with the stem so you can feel if the CR gets pulled downward when you START the bike.
5. Press Run then Start (I own an EFI bike so I'm not sure if you need to press RUN first).
6. Could you feel the CR plunger move downward?
7. YES...Good, ----------NO...Bad CR unit, bad connection or EHC.
Make sure WIRE CRIMPED connections have a tight CRIMP for ALL battery connections.
RRRUFF
BigMack73, check your negative battery connection at the starter mount bolt and be sure it is tight. Also check all your crimp connections at the battery and the starter. You are not getting enough power when you try to start. Horn beep, lights flashing is a good indication of this. Either bad connection or bad battery. A loose or bad connection will cause the battery not to charge. And just because you have a new battery doesn't mean you have a good battery also. You need at least 12.8 volts at the battery before you try to start the bike. Compression release only stay open for about 1 to 1.5 seconds when you hit the start button.
mmachine
Voltage and compression releases
Your 07 Big Dog should be charging at idle when it is running. The battery has to get AT LEAST 13.5 volts to receive a charge. If the battery is low (as if you just started it) the charging system should be putting out 14-14.5 volts or so, but may need to be above idle to do it. I have installed at least one TruGel battery that was bad out of the box and another that didn't last a week. But even a good battery will have serious problems starting a 117 if even one compression release is not working. As mentioned above, check that both are working by lightly touching the top of each while trying to crank the bike. They should pull in as soon as you hit that button.
Roidz
I'm having a lot of these same issues with my K9. I'm getting a new battery tomorrow and hopefully that fixes it. Good luck with yours.
oldmutt
I was having the same problem and I jump started the bike with my truck with the motor off. If is spins it is the battery.
Kdub
This may be stupid, but make sure you hold the start button down until it starts. My k9 when I start it especially cold I have to hold it down for a few seconds. On the initial push it will crank then nothing, then roll over if I continue to hold it down. If I dont that's when I get all the weird speedo things.
BigMack73
Sorry for the delay on the reply, got dispatched to south Florida on Wed/Thurs did not get home till today. Here is where I am at:
1. Got the motorcycle to crank (on first Crank attempt) by jumping it off with the old BDM Battery jumpered to the new TruGel installed on Wednesday morning. Measured the DC Volts to the battery Pos/Neg terminals while Running (holding throttle at 2000rpm) again, it was still fluctuating between 13.65 to 13.75/13.8 DC volts. Per suggestions in thread, (and 2008 Big Dog t-shooting flow diagram) went through flow for Running Voltage below 13.8 Volts.
2. No current drain on battery with Bike off!
3. Running Battery volts below 13.8 at battery (13.7v) flow (and ringo) says to check voltage at each of 2 Circuit Breaker terminals. Voltage same at both terminals with Bike off (13.45v).
- Checked Voltage Reg ground from VR case to Battery terminal, should be less than .5 Ohms. Taking MM Lead resistance into consideration, the difference bet VR case and Battery ground was 3.2-3.5 Ohms!! (Too high!)
At this point I got dispatched on Wed. for my job, had to leave bike. Left my old/original BDM AGM battery on the Schumacher battery charger to be charging while I am gone for work.
Pulled the new TruGel Battery from K-9 to take with me so I could get it load tested proper!
On Thursday, finally had time to take NEW TruGel battery to an Advance Auto Parts in south Fla, (since that is the same chain as in my local home town), they tested battery and said it was DEFINITELY breaking down under load. Gave me the printout so I could forward with the Battery in an RMA situation.
NEW TRUGEL BATTERY IS BAD FROM FACTORY!
OK, that is one issue confirmed, called my Friend I got the TruGel from and he setup for me to Ship TruGel back to his supplier, I got it in a USPS Flat Rate box and shipped it back that same afternoon. Replacement TruGel battery should be in my hands early next week (Tues/Wed).
Finally got back home this evening (Friday) had time and enough daylight left to work on troubleshooting the K-9.
1. Re-checked battery connections, per suggestions, got out my crimper tool and hit each crimped connection, especially the Blk/Red ones going to the EHC, and gave each one a "Tug" test prob pulling with at least 5-8 lbs of force (way more than I ever tug on the connections I crimp for my job) and none failed. I am confident crimps at all battery terminal lugs sound!
2. Continued in BDM 2008 T-shooting flow for charging system, pulled VR and checked/cleaned the Stator connections cleaned and retightened down VR to bike mount. Was a little gunky under the frame, so was thinking the cleaning may help some (one Biker mechanic friend said maybe to install 'star' washers under the Big Dog VR to improve ground?? I just went with cleaning and retorquing the original setup). Also doublechecked the Started Pos and Ground connections for good measure, to insure they were tight.
3. Re-installed my original BDM Battery from off the Schumacher charger, wife had told me it went to 100% on Thursday night after hovering at 95-96% all Thursday evening after she got home from work. (Good to have a wife who will remotely update you on battery charging status!! HAHA).
4. Was able to crank bike after a couple of turnovers, I had my left index finger slightly resting on the rear cylinder Compression release while hitting Start button, felt it click downward, and after a couple of turn-overs the K-9 roared to life!!
5. Checked running DC voltage at Battery Terminals after letting her warm for a minute or so (to smooth idle out) and measured:
14.4 DC Volts!! (Up from 13.7 previously)
I am man enough to say that I was so excited I about soiled myself with pride... :up::up:
There is something about the feel that comes with accomplishing working on your own bike (when previously afraid to touch her for fear of "Frakking something up!") so I seem to be making headway.
Was starving and wife had been waiting on me to sit down and eat supper with her (after not seeing her for a few days...) so, had to leave my girl (K-9) to go spend time with my Number one Girl! (But, we all know which 'bitch' is REALLY number one, right guys?? :cheers:)
Should be a nice Saturday to ride tomorrow, will report any problems or issues if it occurs. I am thinking that my original OEM BDM AGM battery may have been a little sulfated?? and the gunky VR ground connection to the frame may have been affecting my running battery voltage charging levels, causing the original BDM battery to grow weaker? Dunno, but right now all of this fits what has transpired, AND, all the other 'Hard Start' or 'Locking during Start' symptoms come from having a weak-azz/subpar battery trying to crank up a 117ci monster S&S engine!! That is my theory and I am 'stickn too it'...
THANKS FOR ALL THE HELP SO FAR!
Now I will see what happens when the new TruGel battery comes in, knowing full well I may have spent $100 dollars on a new battery I might not yet have needed! Oh well, will test it when it comes in, and may just keep it trickled charged up on shelf ready to replace the original BDM battery when it finally fails for good!
Till then, if all goes OK, will just live with slightly weaker CCA turn-overs from the original 5.5 yr old BDM battery - if I can get the Dog to start every time! :2thumbs:
Gary "BigMack"
