06 pitbull
06 PITY
Iv got an 06 BD pitbull. Replaced EHC with Wires Plus an everything works properly lights/t-sigs/B-lights/Run lights/headlight,,turns over strong but No spark?? Iv got No power comin in to the coil thru the coil harness an wondered if someone can help??
DRBarnhart
Insert title here...
Got power going to the ignition module? :confused:
Dennis
06 PITY
No power to the module as far as I know?Nothing lights up on it..Have power to the Voltage Regulator but nothing coming out and I'm not really for sure if I'm even testing right either tho?? Thought this woulda been an easy fix now its turning to a NITEMARE!! Help!!!
Mojo
If you are saying that you have power on one side of the circuit breaker and not the other, push the black reset button on the circuit breaker. As for the ignition, a red LED should light on the ignition module with the key on and pushing the run button. If it doesn't light, check your power (red) and ground (black) at the ignition module.
DRBarnhart
Did the bike run before you did the WP? And check for power and ground to the ignition module like Mojo has already mentioned.
How are you testing it? Black meter lead on the battery negative and red on the each side of the circuit breaker?
A WP will only fix a bad EHC. If you had the no spark and no charge issues before you'll still need to fix them...
Dennis
