Yeah, checked tire pressure awhile back, it was at 30 and I went WTF?? filled it to 40 psi, went for a ride and it vibrated like a massage chair...came back, let the air back down to 30psi and no more vibrations....:2thumbs:I ran mine at 40psi for months, had a new rear tire fitted and my mate who owns the bike shop said he didn't know what pressure i was running it at so he set it at 22psi, when i told him what the recommended pressure was he couldn't believe it for a rigid. I rode it home and it was like i was riding a soft tail, have been running it at 26psi for the last 500 miles and cant believe what a difference it has made and it handles no different to what it did before. Still shit. lol
Andrew is correct! Lowering the tire pressure may make the ride FEEL smoother, still doesn't take the PRESSURE off the frame...have it fixed correctly!The guy has no clue on what is involved with a cracking of metal obviously. He should be looking for ways to fix the crack rather than telling you to lower the tire pressure.
If you can clearly see a crack in the frame, you need to get it fixed by a metal fabrication shop. One that has repaired frames and knows how to TIG weld. If you were closer I would help you out. Just did 2 American Ironhorses last month with cracked swingarms.
Good luck!!
:iagree: X2Andrew is correct! Lowering the tire pressure may make the ride FEEL smoother, still doesn't take the PRESSURE off the frame...have it fixed correctly!
Good luck!!
