05 Ridgeback Trail Calculation
antvalentin
Anyone know what the BDM factory says a stock 05 Ridgeback trail is supposed to be?
I have read all of the threads I can find regarding rake and trail and I even used the trail calculator on the RB Racing site. My problem is that I have pretty much come up with different measurements everytime I measure the freakin fork length and offset - they can be tricky. Measure from the top of the trees or the bottom of the top of the trees? Measure to the axle or to the bottom of the fork? Having an inch or two variance in measurments can throw off the trail calculation pretty significantly.
:bang:
The only thing that I am actually sure of with my measurments are the neck and tree rakes since I got them from the specs sheet. Everything else is up for debate! :confused:
Only measure from the bottom of the top tree (mfgs. all use different thickness) and only measure to the axle centerline.
antvalentin
And offset? Is it the center of the neck to center of fork leg bolt (or something like that)? I read in other threads re: rake and trail that all offsets were 1. I just dont know if that was for all BD bikes or just the ones you guys were discussing.
