05 RIDGEBACK PETCOCK PROBLEM?????
Chopper117
Chopper Nutt
I washed it in warm soapy water and let it soak for a while and then let it dry and then LIGHTLY sprayed oil on it and let it dry overnight with a fan in front of it.
Ok, just making sure.
It's a fuel issue not a "lack of air" like we were all previously thinking.
Just go ahead and remove petcock & check it out. It only takes a few minutes.
I can't imagine how any excess oil on/in the air filter could foul up anything in the carb. here.
Check it out and let us know!
:cheers::cheers:
Taking a step back...... You didn't have this problem before you oiled the filter? And all you did was oil the filter?
Nothing else was touched?
Chopper117
Chopper Nutt
No motor work yet. It started to do this after I cleaned the K&N and I used to much oil on it and thought that might of been the problem.
Ok, so your original description of "when" the problem started was correct, "immediately" after over oiling the air filter. Nothing before that time, correct?
Nothing else was done or adjusted at all, correct?
Since then you've washed it out, let it dry, and lightly re-oiled it, correct?
And your still encountering the same stumbling problem "only" in 1 gear and "no" stumble whatsoever in all the other gears, correct?
Just want to make sure all of these comments are correct.
When you removed the air filter to wash it out, what did the throat of the carb. look like? Lots of oily residue all over it?
I won't be around here much today, in & out all day. So guys what I wondering here is if the excess oil was sucked through the "Squirter Venturi" and in someway stopped it up or partially blocked it. It'd be a first for me, but I can't see how the induction of any excess oil into the carb. could affect it this way. The throttle body venturi (throat) is not open to any other areas other than the air filter(outside) and intake & head (inside).
I'll check bak in as soon as I can.
"Curious minds want to know" WTF! :D
Good Luck! :cheers::2thumbs:
RCAdd1ct
JAFO
If so try it without the filter.
Shouldn't hurt to go around the block without a filter unless you are on a dirt road.
jimizee028
TRUE COLORS COLLISION
you sprayed oil back on the filter and then let it dry overnite?????i would let it dry overnite and then spray oil onto it,the oil wont allow it to completely dry....anyway maybe too much oil passed through and somehow someway partly fouled a plug???maybe remove and clean or just replace?????
I've been thinking on your problem this morning during my travels!
Ok, you saturated the air filter with a "lot" of oil! To the point that the air filters excess oil could just drip off, right? So you cleaned out the air filter, but the stumbling was still there, right? Now we've all been wondering how "could" this previous saturation of oil it affect the operation of the carb. to cause a stumble, right?
I kept going over and over all of this in my head, and as to what you did to correct it and what still resulted! I just couldn't figure out or see "how" that could affect anything with the operations of your carb!
Then it hit me like a ton of bricks!...DUH!...Like I said :loony:
"It shouldn't nor couldn't"! and "It Didn't"! :eek:
The excess oil got "sucked" into the carb., right?
Check the "SPARK PLUGS"!......I'm :loony:
I have the feeling the oil saturation may have been great enough to completely make it through the carb., and straight into the combustion chamber and foul the plugs.
Im sorry! I may be slow"er" :loony: these days, but I'm still here trying! :lol:
"I think":lol: we may have the explanation here!
Good Luck!:2thumbs:
MARV
good trouble shooting but i guess it sounds better when thedeadone says it! :roll:
sounds familiar.
:lol::lol::lol::lol::lol:
I'm a little :loony: this morning!
Like I said...Duh! :lol:
Sorry Jim, Your post wasn't there when I started typing! :lol: Too many interruptions!
Good Job Jim! :2thumbs:
We both thinking alike here. :2thumbs:
Just don't get sloooooooow like me! :lol:
I must be like someones signature states on here: "There's not cure for "STUPID"! :lol:
:2thumbs::2thumbs::2thumbs::2thumbs:
Chopper117
Chopper Nutt
:cheers:Hey guys, I appreciate all the feed back that I'm getting. I pulled the Petcock last night and it seemed fine and gas was flowing fine through it and the screen was clean as could be so I don't think the Petcock had anything to do with it. When I get home tonight I will pull the plugs and see what they look like and I won't be able to test drive until Friday evening to see if it is still stalling in first gear. If the plugs are fouled, I should know just by looking at them right?
jimizee028
I THINK PLUGS MIGHT COST YOU $10 pick up a set and put them in and be done with this tradgedy....get in the wind i am allready slow...i started writing that reply yesterday.........................:cheers:
