clay5769
Hi all
FYI I just did a 05 Chopper Final Chain Drive Conversion...
Other then needing a couple of Spacers/Washers for the front sprocket..
There was a space between the sprocket and the nut I made 2 washers works perfect.... I did not have to cut my clutch cover or grind it at all..
Here are the parts I used..
PBI Front Sprocket 1/2 offset ...Part #280-5 Speed 24 Tooth.........
(I have the six speed but PBI thankfully sold me this one I had ordered the 6 speed version which will not work the 6 speed I have is 5 speed shaft )
All below from J&P I also ordered an extra master link to carry like in the old days.. (I'm 56)
I also used red lock tight on everything and while doing this job , I found front bottom motor mount bolts almost fallen out....
Rear sprocket Part #600-0531 48 tooth sprocket
Part #600-985 ....530 X 120 Chain (I just went for cheap)
5 ea grade 8 Bolts (for the rear sprocket)
Best thing I ever did I love it... It even feels like it pulls better and NO MORE DAM BELT SQUEAL......:2thumbs:
J&P total $147.58
PBI Sprocket's Total $71.15
Grand total with shipping and the homemade washers and 5ea grade 8 Bolts ($15.00)
$233.73 complete...
(while I'm riding) and restart it its ok for the rest of the day....and I don't have a problem until the next time it decides to stop..
