04 dog sputtering / coil wire
Freak_zilla
Hi I recently purchased a big dog.
I have seen some similar topics but no fixes,
The problems I am.having is
1. Bike will miss / sputter at higher rpm and then run like crap, at the same.time the tach lights will flash n try to go off. " "happens when you give it full throttle "".
Bike runs and starts fine at low rpm
2. After this issue happens. The plug wire pops off the coil and then runs like crap and dies . I then have to take.cover off and put wire back on.
I open the gap size on the hole hoping it was just loose but same.issue comes up.
I dropped it at a shop and he said it popped off on him to.
thing is I switched the wires and forgot to ask.him what wire fell off.
I was trying to see if one side of the coil was bad or Maybe a wire.
shop is closed and bike still there. He said maybe electrical or something with tachometer.
I hope I explained this enough to get any answers that will.help my problem
if the wire keeps popping off, try to find a way to hold it in place with a plastic wire tie and see if that helps any. try cheap first. :2thumbs:
Freak_zilla
The thing is. Only pops off when high rpm and full throttle not normal riding.
there's got to be a reason for this coil.wires usually just don't.pop off. Lol
HotRod
I have a zip-tie around the boot on mine too prevent them from coming off. also die-electric grease and heat shrink all connections. these things vibrate and it could be loosing a connection at high rpm.
I had an 03 chop that liked vibrating one of the plug wires off. Butcher has it right. Wipe off the coil and the inside of the plug wire with alcohol. Push the cap on and zip tie it. Solved the issue on my 03.
Explain "High RPM"
If the plug wire pops off the coil I hope it runs like crap :rofl:
Might be worth while to get a new set of plug wires, not sure what you got but its generally just a thin piece of metail in there and it could just be stretched out allowing the plug wire to pop off easier than it should. It has happened to me once before.
Freak_zilla
Ill try this next week after the bike comes back,
But it will only pop off after higher rpm driving, so my question is when I hit say 4000 rpm. And it starts to sputter, but doesn't fall off would this miss be caused by maybe the wire moving? Or loose?
I have seen some wires that are barely on. Bike runs fine until it falls off.
my bike sputters only high rpm even with wire on tight as far as I can feel ..
Ill try all this and hope.forbthe best. Thanks
could take a pair of pliers and squeeze the wire end a little so it is harder to get on/off and thereby make better contact but i would still try the wire tie. logic only tells us that the more rpm something is turning the more vibration it is going to create.
If tha motor is missin out at 4000+ and then the wire is comin loose. That sounds like the wire is your problem. Might do as the others have said and zip tie the wire in place.
Also would be good to check all your motor mounts to be sure everything is tight and know excesive vibrating is cuasing the wire to come loose.
If you zip ite it and everything works I would get a new set of wires and tie them as mentioned. You can fix this with out payin the shop to do it.
Freak_zilla
Well I picked up the bike. But the roads are wet.
I opened the coil wire some and then zip tie wouldn't stay good so I used some.black 2 sided goo adhesive stuff,I got on it a few times and it dermatology be better and missing is less its hard to tell with wet roads. But I do feel the difference! !! I hope this is the main issue and.ill add some more adhesive tape.
Now I noticed another issue ill post here and as well open a new topic. If no answers
My tachometer / speedometer has rpm lights. Some yellow green and red. Well they are all flashing like a Xmas tree when I drive n then stop .
if I'm at a light and rev it up the lights go away and just show the rpm light
but once I drive it again all the lights go crazy,
Any one know a fix for this?
Freak_zilla
Well problem has been temp. Fixed.
Using tar tape and zip tie did work. Problem is high rpm vibration causes coil wire to pop off. No bigger issue , bike runs strong now. Not sure if coil is bad but
I think ill try a new or different coil to see if i dont need all this extra help .
So thanks for the help . And for other readers now they know the answer
Freak_zilla
