Thanks for any suggestions on this problem. I installed the WP Kit on my 04 chopper and I'm now having a strange problem. My bike cuts out at 4K RPM whether a hard acceleration or a gradual increase in RPM up to it. I checked my gas cap vent and cleaned my carb jets just in case because it had sat for a while. When it cuts out I back off the throttle and it restarts on its own followed by a backfire out the exhaust. It will do this three times on the third time tach goes out and I have to pull over and cycle the ignition switch to restart it. Other issues possibly related: when ignition switch is turned on right turn signal is on? and Speedo doesn't register correct speed (not a new problem). I have driven a few hundred miles staying below 4k RPM with no additional issues. My ground wires are are soldered together and going to the frame I am changing this today and connecting direct to the battery via a 10Ga cable. Help please.
