2004 Chopper, 117ci. No spark. No light flashing on the Thunder Heart ign module. Bad sensor plate? If so, what would you replace it with. Another from Big Dog, HD or what aftermarket? Ohm test on coil checks out.
What, if any problem would a broken wire to the front brake switch cause? It's broken at the circuit board. I'd rather it didn't work anyway.
Since this is actually an aftermarket system, what years do I look at for components. Pre 99 or 2000 and later? The S&S Sidewinder would be like an Evo motor, correct, as far as configuration and parts?
I forgot to log in. Sorry if this shows up twice.
Thanks guys.
Thanks guys.
