03 pitbull compression release
THUNDER
does the 03 ppitbull have a compression release, It has the 107 S&S, I read that some have them when you turn the key on and hit the off and on switch, don"t know much about this motor but learning lot"s of things quick....
pig pen
No releases on the 03. The heads are ready for them and the bike is also wired for them.
THUNDER
Thanks , this is a great place, I have not ask a question that I did not get a quick and accurate answer, thanks again.....
As stated your 03 is ready for them. Just plug them in to the wiring harness connectors under the tank. But you will need an 02 starter relay and if you get the BDM CR kit it should have the relay in it if I remember right.
